- LS3 motor with cams, ZO6 intake, and full exhaust = 400whp easy and maybe more.. A simple hook up of my nitrous dry system and then I got real potential to motor hard.
Jib
You have to video the melt down or at least the attempt before you pull the 1uz out. Foot to the floor in neutral and see how long she runs at full rpm. We could run a sweep stake on the closest to the time. You could always hit the NOS at full rpm to help things out if she won't blow.
How much is an LS3 crate motor in the States now?
Australia they are $6,500 Au including flywheel & clutch.
Very true, power would be incredible.
But I doub't you'll make the same topic as this about an LS engine after a few years of abuse![]()
I dont see how the nitrus is maxed out at 150, just take the pill out and you should end up with a 500-1000hp shot..
