Which ECU
Micky.D
Hey guys , I purchased a 1UZ with loom / trans / and ment to be ecu, I later found it is the abs ecu, so my issue is I don't have an ecu, there's heaps on eBay etc , but everyone tells me a different part number to get so now I'm confused lol, my engine details are
From a 1990 celsior , has traction control throttle body ( don't want it to run the traction control , going in a 4runner
Vin 6U900UCF110011128
Engine 1UZOO88873
Loom part number 82121 50101,
Please help :)
I'm at the stage of looking at a carb setup lol,
Mike
89661-50100 is the factory fitted ecu for that setup. It is one of the early UCF10/11 ecus with the 26P 16P 22P 26P. I beleive you can also use 89661-50102. In the early series of this ecu there is a difference in the trans solenoid plug with one having 6 pins and the other 8. Cheers
Does your trans have the 6 or 8 pin solenoid plug? I am running a 100 in my present truck with the 6 pin gearbox plug. I have a couple of 102 ecu's - one came from a vehicle with a 6 pin and the other with a 8 pin so one of them is not a match. Cheers
Swappig to a carb is harder and more expensive than staying with EFI which is more reliable, more economical and doesn't car what angle you get the car on.
Thanks gloverman, I'll have a look tomorrow night , I'll get back to you ,
Thanks Zuffen, yeah I don't wanna go that way , lol , injection is my friend ;)
