skraggy_uk
OK, I have a 91 Celsior. I bought it for bargain bucket money, so the minor flaws and lack of history aren't a problem. I can either drive it into the ground and lose nothing, or have fun now, spend money when needed and fix it up.
It is a UCF11, but the airshocks have been replaced with fixed height/damping shocks and springs.
The good side to this is that it has a loverly smooth ride, the bad side is it rolls heavy on corners, and dives like a submarine on heavy braking to a stop.
Cost wise I imagine that it won't be much different importing refurb airbags from the US, or a set of JIC Magics from elsewhere (assuming the pump/pipes/wiring is intact and working).
I have the pump in the trunk, and what looks like a nitrogen cannister on the LHS under the hood, plus signs of wiring arround the front struts which still have the "TEMS" plastic caps on.
Which would you do? I will tune the motor eventually, but there is enough performance currently to overdo the handling ATM. brakes wise, if they are available, I plan to fit DBA brake discs, and Akebono Ceramic pads or equivalents. I fitted them onto my old GT-Four/All-Trac and they worked harder, cooler and with less dust than standard kit.
BTW, I haven't looked under yet, but do the air suspension models have sway bars fitted?
I'm in the UK which hampers available kit for reasonable money.
