Most 1uz ive worked on with stock intake and cams have idled between 60 and 67 kpa map. Thet tend to pull around 80kpa map on decel. Ive had the odd one pull 88 on decel which was a pain as the normal map sensor I run would hit 0 volts causing the ECU to use a default value with the end result a huge backfire down the exhaust and local thinking a shotgun had been fired. Change of map sensor required.
I think the lowest readings at idle I have had is around 50kpa map. Doing a twin turbo thats due to fire up this week so will be interesting how that on goes as it has some 264 cams in it. Overlap isnt too bad though.
