R .rampage. Member Messages 30 Location Las Vegas nv Aug 11, 2014 #1 i have finally got my supercharged 1uz running good only running abut 6psi at 6000rpm what should my AFR should be?
krayn Member Messages 511 Location Victoria, Australia Aug 12, 2014 #2 Required AFR will vary depending on load, temp, rpm. Do you mean what AFR while at full load at 6.5 psi?
S stevieg New Member Messages 228 Location lethbridge alberta Aug 12, 2014 #4 Afr under boost is safest if kept under 11.8, unless your ignition map is perfect you can bump that up to 12.2 is the leanest I go on a boosted motor.
M markstoys Member Messages 147 Location Duarte, CA, USA Aug 12, 2014 #5 stevieg said: Afr under boost is safest if kept under 11.8, unless your ignition map is perfect you can bump that up to 12.2 is the leanest I go on a boosted motor. Click to expand... Mine has lasted 5000 miles running these numbers at 10 lbs/6000RPM--and it spends a high percentage of its time at WOT.
R .rampage. Member Messages 30 Location Las Vegas nv Aug 14, 2014 #6 Ok cool thxs on stock injectors seems like I'm getting about 12 leans out to about 12.5 maybe I bump fuel prx up a little bit
XR8tt Active Member Messages 2,758 Location Sydney Australia Apr 10, 2016 #7 Check that fuel pump is up to fuel supply at the higher fuel pressure ..
