ekoston69
- Messages
- 5
- Location
- Perth, WA, Australia
Ive had a read through alot of the conversion threads involving mk3 supras and the 1uzfe and it seems pretty obvious that custom engine brackets need to be made to suit the supra crossmember. My question is has anyone got this to work with the early model's crossmember or will i have to use the later mk3 model crossmember with the round mounts? Also how far forward/back will i need to mount the engine to bolt up to the standard bellhousing position? Does anyone have any measurements/photos? I will be most probably be using a crs 1uz to w58 bellhousing, not sure if that is the same length as the supra housing..
cheers
chris
cheers
chris
