Torquing Patterns
tsirovy
:firedevil: How is the pattern when tightening/torquing the main crankshaft caps?other than tightening the nut before the bolt.
Ok then heres another one. How is the direction of the main caps facing for reassembly? bottom of the number facing towards the front of the engine or bottom of the number facing the rear of the engine? One way the notches on the bearings/cap are on opposite sides of eachother. The other way the notches on the bearings/cap are on the same side as eachother.
Can one plug and play by dropping a 1995-1997 1uz-fe into a 1991 frame and with the original 1991 wiring setup?
I figure from other vague diagrams that the main bearing caps have to go in so that the notches on the bearings are touching eachother. Moreover I figure the only tightening pattern for the main cap is to tighten the nuts then the bolts and thats all there is to it. And hell no you cant just plug and play a 1995+ engine into a pre 1995 set-up. The newer 1uzfe uses the OBII diagnosis and other wiring set up and the old 1uzfe uses the OBI set up.
