I’ve been a bit bored the last 8-10 months, waiting for my 1UZ motor and V12 motor to make some progress, and an idle mind is the devil’s playground. So during this time, I’ve been fooling with another idea. A 2JZ-GZTE.
For those familiar with Toyota engine nomenclature, the “Z” means supercharger!
Yep, I decided to supercharge the 2JZ-GTE motor. It’s something that AFAIK has never been done, and it’s just been begging for someone to do. People have hung centrifugal ‘chargers on their 2JZ-GE’s but that’s a waste of time & money. IMO, they should have just turbo’d it.
OK, so why don’t you just call it the 2JZ-GZE? Why GZTE?
Because it’ll have both a turbocharger and the supercharger(s) :wink:
Holy *!@#%^ :yikes:
Now, why hasn’t the 2JZ ever been supercharged? Well, it’s an inline six cylinder motor, which is a mother bear to try to fit a Roots style supercharger on.
Plus, the front of this motor is very busy, so there’s not much space for a centrifugal. Besides, a centrifugal has a very turbo’ish power curve, and the 2JZ really doesn’t need a slow starting power curve. What this motor needs, as we all know, is low end torque, which is something only Roots or screw type superchargers (or nitrous) can provide.
So, due to packaging problems with putting the usual Eaton, Whipple, etc. on this motor, no one has supercharged it…… until now.
Here’s the concept in a nutshell:
1) Fabricate a new common plenum intake manifold which allows the supercharger(s) to bolt to it and then the head, and still allows room for the injectors and rail.
2) Bolt up (3) 500cc mini superchargers to this manifold
3) Mount 3 ITB’s to the superchargers for dyno testing; otherwise construct a common intake with a single TB for mounting in the car.
4) Construct a jackshaft driveshaft for the 3 mini superchargers.
Voila, we have the equivalent of a 1.5 liter supercharger, for a 3 liter engine, which should produce around 1.0 bar of boost when overdriven at a 2:1 ratio, and it’s still “fairly” low profile and should fit on the intake side of the motor. It should also produce oodles of low end torque, and once the turbocharger is hooked up, and is putting another 1.0 bar of boost at the intake of the superchargers, the motor should start making stupid amounts of power, pretty quickly.
So here’s some pics of the progress so far:
Here you can see the mechanical fabrication of the intake manifold is nearly finished (still has open ends) and the superchargers are bolted up to it and the manifold is bolted to a 2JZ-GTE head. Note the injector bungs on top. Those were a b*tch to get in and get right.
The throttle bodies are from a Suzuki 750 GSXR. Air horns are from a set I picked up awhile back off eBay.
The business end of things. These ought to sound pretty sweet up around 6500.
Still to come, tying the TB’s together, working out the throttle linkage, and fabricating the Gilmer drives.
I’ll also need to fabricate some stout knee bracing for these things, as they’re hung pretty far off the edge of the head.
Now, will it all fit in a Supra? Nope, no way, not with the ITB’s, but the next step after the ITB’s will be a common intake plenum, with a single forward facing TB, as per the OEM 2JZ-GTE setup, and that should fit!
:banana: :banana: :banana: :banana: :banana: :banana: :banana:
There will of course be some other fitment "issues" to work around, but those will be sorted as we come to them. (Take heed of this, all ye copycats who would take the idea and try to turn a fast buck on it before it's sorted!)
So watch this space; it ought to be a fun project :burnout:
Holy *!@#%^ :yikes:
