Regarding your concerns.
				jibby said:
			Any new news on correctly blocking the EGR on a California USA 1992 sc400?  I am about to install headers am I screwed is it going to scew up my ECU and fuel mixture?  What is the correct way to block the EGR?  Can a Piggyback ECU help?
Hello Gibby -
Seems my post you quote has you spooked and  frustrated .
Let me ease your mind a bit.
Regarding my posts. 2 things
#1) Frankly, I post what I've experienced from truning wrenches on my cars.  I found 1st hand some solutions simply did not work when I personally tried them.
#2)  I avoid  those wanting to debate since I  don't give a S(*#T!   if people agree with me or not. I spent the last 4 years working on two SC400's. I do all my own work and have  put over 500 hours and 25K into my current engine.  I'd like to think I  know a little about this car as a result.
As for your 2 concerns:
 I have the  S&S headers on my own ride.  A few minor issues were
Issue #1 -The flange and the hole pattern needed to be modified as they did not line up with my cats. I made some to hit and replaced them in about 2 hours. I suggest when you order yours,  specify your cat or better send them the pattern so they can confirm it will fit your car.
 Issue #2 - I needed to clean up some welding snot left on the the inside of the headers. Also needed to grind down 2 areas that portruded on the inside oft he left side header.
Issue #3:Note : I had short aftermarket cats and they still hang about 1-2"  to low after adding the headers. I am  in the process of modifying my exhaust setup and will adjust then  so this is not a big issue to resolve for me.
Unless you are doing the same, suggest you read jBrady thread on the headers and see what might be a easy solution/alternative to the cat clearance issue.
All and all, IMHO  - they are a  excellent buy and good quality header.
 I am very picky about what I find acceptable. I like them..
As for the EGR issue. Let me say I've learned not to  anyones word for anything. This includes me.
I I suggest you get out a Lexus service manual and read it and decide for yourself.  That said, you'll see the soarer AUS. , Canadian version Lexus ( see via serial number identification for intended destination ) US versions and California versions are all setup to handle  EGR  differently. Check to see if  yours is electronically or vac controlled. AUS. soarers are not an issue as EGR is vac controlled. Vac controlled ( as per people I deal with in AUS tell me) can be eliminated and will not effect computer/car performance. MY car is a canadian car and is a hybred and not an issue. My 1st engine came out of a  California car and always ran rich.   In 1992
I discovered the EGR setup was different  for CA. destination delivery then other states. Don't take my word for it. It spells it out via a disclaimer in the service manuals. My 4 years working on this car taught me that if it runs threw the electrical/computer and your screw with it... it will let you know it.
That said, if you try something that dosn't work, you can change it back and try again.
I suggest you see what setup your car has and compare it to the service manuals and start there. Good luck, its a great car with one of the best engines ever engineered. Have fun amigo!!
