Specs / type of the 1UZ-FE Crank Trigger
MikeMan
Does anyone know what P/N / model / type of crank trigger the 1UZ-FE uses?
I have a good mate of mine who is an absolute genious at tuning the Nissan factory ECU playing with a VH41DE computer map to see if we can make it suitable for a 1UZ-FE for my Starion.
This would give me almost standalone tuning with capabilities in the Haltech E8 type range for factory ECU money. The ECU is good to 12,000RPM on a V8 with load sites every 500RPM I think, maybe even 250RPM sites (Some of the 4 Cyl ECU's are 250RPM I think)
If we can get it running that computer is good for over 800HP on a turbo 4L v8 with the right program on it, all Nissan ECU's have the capability to read a 3 bar absolute MAP sensor.
I will let everyone know how this works out.
will be hard to do using 1uz sensors
maybe try fitting nissan crank sensor to 1uz
nissan uses 4 wire crank sensor
power
earth
signal every 90 or 120 degrees 4 or 6 cyl
signal every 1 degree
the above signals are optical signals and im pretty sure are square pattern
the 1uz uses inductive signals
8 pulses on 2 wire sensor on crank
4 pulses on 2 wire sensor on each cam
it could work if u had all the stuff
but i its goin to cost too much there are much easier and less stressful ways
nissans vq45 engines run an airflow meter
how do u get a 3 bar map sensor out of it
do u mean it can just read that high
Been awhile since i looked at this but IIRC it is actually 12 pulses per revolution on the crank (1 pulse every 30 degrees), so 24 pulses per engine cycle. The TDC pulse (if you call it that) is 10*BTDC and the next is 20*ATDC and so on.
Each cam has 1 pulse per engine cycle, so one every 2 engine rotations. And again IIRC the right hand cam sensor pulse is at 15*BTDC of #1 and the left sensor is about 15*BTDC of #6 or the sensors may be the other way around.
Both Cam & Crank sensors are 2 wire reluctive type (magnetic pickup). Crank wheel is 12 tooth as MaxPower said below. Here's a C&P from the '95 LS400 NCF:
Hate to bump such an old thread, but can anyone verify the 15*BTDC #1 cylinder for the right side cam position sensor? Also, right side being passenger? I thought it was that side (G2 sensor), but I also thought it was at 5*BTDC. Thanks for any verification.
