SOLVED THE Battery/alternator problem(interesting, may help you)
B-FISH
ya so everyone and their mama said that i simply had a bad alternator, except me, n e way the problem with mine was the ground bolt on the alternator was ol and fu#ked up. so bad that it snapped while being unscrewed, so i cleverley,and simply,haha, just put the wire lower on the ground bolt....
Good work! Most everyone overlooks ground wires when troubleshooting anything. Grounds are very important... grounding the engine even will show improvements, grounding high power stereo equipment, ground when your welding :reporter: etc etc.
I always say if something is broken then there is a reason it broke... if not just designed wrong.
