- 5,633
- Sydney, Australia
This idea has been kicked around a few times, but now that cams are going to be readilly available it probably takes on more priority.
When changing cams, or just setting the valves you need to change the thickness of the shims used to adjust the valve lash.
These shims are quite expensive ($12.50 Aussie last time I looked) so the idea is we establish a central collection of used shims and trade the shims we hold (and you need) for the shims you hold (that we can re-use) to save the cost of new shims.
I suggest we establish a system whereby anyone with spare shims send them to us and we will hold them until needed by a member.
We then post the member the required shims (assuming we have the shim they want) and they post us theirs AND send a fee for the new shims to lextreme to put toward the running costs of the Site.
I'm happy to hold the Shim Bank and post the shims (at my cost) anywhere in the world.
I'm looking for feedback from you the members as to whether you would use the facility. Assuming you would use it, what's a fair charge for a used shim?
Any alternative sources for shims would also be usefull.
