SC400 Wiring Diagrams
Wiisass
Does anyone have anything better than what's posted in the MISC. section or at least the rest of the second page posted there?
The motor I have and wiring harness are from 96 or 97, so something from those years would be best. I'm just looking at stripping down the harness and getting rid of everything I don't need, but I need to figure out what everything is first, so I'm not getting rid of something that might be important for some reason or another.
Thanks guys.
Tim
I think the 1992 to 1996 SC400 is the same and slight different on the 1997 and alot different from 1998 to 2000.
So 97 is a little different? Do you know in what regard? The motor I'm going to be using is a 96 according to the junkyard I got it from. And the ECU and full wiring harness that I have is supposedly from a 97. Is there an ECU list somewhere that I can check which year the ECU is from?
Tim
There's a VIN tag riveted onto the motor on the lower right side of the cylinder block. Probably the alternator & power steering are blocking its view, but it's there. With that, you can figure out for sure which vehicle & year it came out of.
Here's a pic of this tag:
