SC400 Roots supercharger kits
UZZ30-Québec
Is there a complete roots kit available (with fuel management and everything that is needed to be boost ready)
How much is it?
I've seen parts here and there but no complete kits. And the Vortech kit for the SC400 on this site seems to not be available. I want to know how much i need to save. would 5000$ be enough?
Do a search for posts by Richwood. Andrew has nearly all the components necessary for a "kit", except for the fuel system.
He makes the manifolds, and offers all the necessary pulleys, and perhaps would provide the fuel system too.
UZZ30-Quebec, give TOM @ BULLET SUPERCARS on 07 33820018.
Have a chat see what they can do for you.
I've seen the near complete kits or richwood, that's actually why i was asking the question, to know if someone could offer a more complete kit. I'm good in mechanic, but not in metalworking and fuel injection programming, so i need something that is complete, bolt-on and very easy to tune (well, at least enought to be able to bring the car to a dyno and tuner specialist).
I do understand that those manifolds are magnificient pieces of art.
Its going to be hard to find a complete kit because companies will not invest into it due to low demand. Specifically, a Celsior Kit might be different from the LS400 Kit even they are the same year. Same as for the Soarer and the SC400. A kit is very specific for the model and year. I think Richwood is as close as you can get. If you are mechanically incline, you should not have any problems getting it done.
As for fuel you can run a FMU assuming you are staying with stock injectors.
.... If only the UZ was as popular as the JZ..... ;)
well, looks like i'll have to go richwood's way. Thanx for replies.
Can megasquirt works with the stock ignition system? i don,t think so because of the 2 distributors?
Mega squirt can do virtually anything.
Junk the stock distributors and use Fords EDIS8. I met the UK importer of MS and he took time out to talk to me about the fundamentals and as a complete novice I think even I could get it to work! Cheap too!
Mark
Andrew @ Richwood or Tom @ Bullet I'm sure will put a kit together for you that will work straight out of the box. Just tell them what you want.
It's a pretty easy bolt on job and with all the parts to hand a weekends work will have you smiling on Monday.
