Fastmotoute - the question of which turbos suit your purpose depends on your application/power goals/budget.
Here are some specs on the s13 T25 turbos you asked about:
Compressor: T-25, 60 trim 56mm
Turbine: T-25, 62 trim 53.8mm 0.64 A/R
s13 horsepower: 205hp @ 6000rpm / torque: 203 ft/lbs @ 4000rpm Stock boost: 7psi
As mentioned, the s14/s15 ball bearing T28s are a nice turbo that would provide a bit more power and good response but they are expensive. The T28 from the GTI-R that e-solver mentions has greater power potential. To use a phrase coined by my old Lithuanian mate Robert, the GTI-R T28 is 'big for it's size'.
Factory Nissan Pulsar GTI-R T28
Compressor: T3 0.60 A/R 60 Trim
Turbine T-25 0.86 A/R 79 Trim
227hp @ 6400rpm
Getting back to the s13 T25 question though, if you use the stock output of the s13 2.0 litre @ 7psi as a guide you could say that you should be able to comfortablly make 400hp with two s13 T25s on the 1uzfe at a slightly higher boost level (taking into account that the SR20DET is likely to make more hp per litre than the 1UZFE at a given boost level). If you're looking to push past about 450-460hp look at different turbos.
In the end it depends on your application - I'm actually considering getting two cheap s13 T25s to slap on my 1UZFE just so that I can get it engineered with twin turbos before rules change.
[FONT="][/FONT]
[FONT="][/FONT]
