running rich???
hilux_bondy_007
hey guys, i have a 1uz in a hilux running a pod and it idels all good but seems to run very rich, when its running all i can smell is petrol and gets alot worse when i rev it hard. here is a pick of my pod and where it is.
any way to lean it out. running standard computer
y do u want to lean it out
u have a faultin the electricla sor a vac leak or this or that
could be a million reasons but dont have time tolist them all heheh
make sure if it idles smooth its hard to tell if it has a miss if yr a novice mechanic
u couldhave a leaking injecotr
or faulty maf or or an air leak or could be anyhting
has it ever run good did a backyard guy do the wiring and it has a problem
is the engine ecu and the engine wiring and the engine all one complete set
or did u buy parts from all over australia
maybe its the hole in the cam cover letting the air in hehe
engine looks in good nic hehe
does it have a miss
Good spotting MADMONT. If the hose to the IAC valve has been blanked then most likely the throttle stop has been would on to make it idle , the ecu then will give it extra fuel as the TPS setting will be incorrect. A good idea will be to reconnect the IAC valve hose and reset the throttle stop using the TPS idle signal as a reference. This may help solve your problem. Cheers
