elliotaw
- Messages
- 221
- Location
- Melbourne, Australia
Im just about to assemble the rings and pistons into my engine.
The engine has been bored and honed to 88mm.
The pistons and rings are all new Ross items.
The paperwork that came with the pistons shows some calculations to work out the top and 2nd ring gaps.
It states that the top gap should be bore dia (inches) x .004, and the 2nd ring x .005.
This equates to :- Top ring = 3.464 x 0.004 = 0.014in (14 thou)
2nd ring = 3.464 x 0.005 = 0.017 (17 thou)
I had the machine shop do the ring gaps for me as I assumed they would do a better job than I could.
I've just checked No1 bore and found the ring gaps to be 17 thou for the top ring and 18 thou for the 2nd ring.
I double checked everything and even set the rings into a different bore incase they numbered them differently but the same result.
On calling the machine shop, I explained the problem and the reply was that he had fitted a gazzillion sets of rings and from his experience the gaps were too small so he made them bigger (hmm).
I'm not doubting his experience, but I'm sure Ross wouldnt have pulled these figures from their behind.
What do I do ?
Elliot
What do I do ?
Elliot
