loosecannon
Hi,
I am using a 1uzfe in an off road application and NOT for the street, and I am looking at a few options at this stage, I will be changing the cams, custom headers, as I need 7000-7500 rpm, the engine will need to be happy at this rpm, If I use the standard ecu, what RPM will it cut the engine, I have heard 7200, also what size or type of injector can be run with the standard ecu instead of the standard ones
Makes me think a carb setup might be or feasible for consistent high RPM
Thanks in advance
Thanks in advance
