Just call me "Lex"
- Messages
- 12,033
- Location
- City of Halos
This is very complicated but i will try to explain this event. Recently I upgraded my LS400 radiator to a Supra TT (Koyo) with 2" thick. The stock radiator doesnt have a cap in it. The cap is at the reserve tank. Anyway, the Koyo radiator doesnt come with a cap. So, in order for the car to run it will need two caps. One for the radiator and one for the reserve tank.
The radiator was filled with a combination of water and a gal of the red radiator fluid. I make sure there is not air bubbles. The car kept over heating and overflowing of the fluid. I kept refilling the radiator and change out the cap from the stock pressure of 13 psi to 16 psi. The problem still occurr. I switch the caps from reserve tank to the radiator and vice verse, but still overing and overflowing.
Change the thermostat but the problem still not going away. So what I finally did before switching back to stock was to modify a cap and delete the spring and seal. Basically I just want the radiator to cap it off and allow free flow of water from and to the reserve tank. The overheating problem solved.
This is an experience I would like to share with you guys. For the past few days this has been giving me hell. Just a cap can cause so much problem.
