Pump output figures
Zuffen
Super Moderator
Staff member
Does anyone know the respective flow and pressure figures for the power steering pump and the cooling fan pump?
Looking at their physical size (and the hose size and construction) I would guess they are quite similar.
I've done search but come up empty handed.
At operating temps (above 80C)...
Power Steering Pump Spec - Minimum pressure @ 1000rpm 75kg/cm^2 or 1067psi!
Fan Pump Spec - Oil pressure @ Idle with Fan At 1100rpm is 12-25kg/cm^2 or 171-356psi
Dunno flow rates though. And yeah they do look very similar inside but the pressures are way different.
Thanks Maxpower.
That's @ 1000rpm I wonder what it's doing at 7,000 rpm as that is what it will be doing at redline. The mind boggles.
