I am thinking of porting the heads on the 1uz-fe myself to create better flow maybe as soon as next weakend.. I have done this on a few of my older SBC heads where I would remove the Chevy heads then line up the gaskets and grind out all the head port holes edges in a circular grind motion to then create a smoother and larger port hole to meet up with where the gasket fits. Then I would finish the job by using a fine grit hand held circular sander to basically smoothe out and polish all the grinded areas.. I would imagine it is no different with the 1uz-fe motor heads... I would always pick up a few ponies when doing this on my SBC heads and exhaust manifolds too where the headers meet up....
I would like to do this same process with my 1uz-fe heads and then really sand and polish out those carefully grinded out circular edges (port holes) to create the best air flow possible.... I always did this by hand by using a hand held circular rotation grinder tool in the past... Grinder and sander bits..
Question, will it make a difference if I do this, and do you think it worth the trouble? Also, I have never really taken a close look at the 1uz-fe head port holes, is there areas on the head port holes that can be grinded like I am talking about? What do you guys think?
Maybe I should have posted this in the Head and intake section...ooops...
