People from oz
Can anyone point me in the direction of this answer will 95 to 2000 model ls400 coilovers fit in a 1990 model. Because i can only find listings in Australia for 95 onwards
Can't answer your question re '95/2000 LS, but when you say better? handling, what do you mean ?
He may be interested in what works and is available there, since he's in Oz too.
What i mean by better handling is, less bodyroll and less tyre screech around corners because at the moment its pretty well dangerous too take a corner with any decent speed... The reason i am asking about australia only is, i have no intentions ordering from outside australia, and at the moment i cant find coilovers for my model 1990 only 95 onwards, Also the reason I am looking at coilovers is because the only brand i can find replacement struts in is Kyb and I would like to have at least two options
I had.... Supra Rears in the front, with 5cm longer shafts, and Supra rears in the Rear, with 10cm? longer shafts...
however, I strongly suggest against sourcing them from the same place I did
95-00 LS400(celsior) specific shocks or coilovers will not work (properly, if at all) on 89-94 models as the shaft length is too long.
89-94 specific coilovers WILL work on 95-00 but the car will never be able to get back to the Original height. (JIC FLT-A2s for example, on a 95-00 at their highest setting, are still ~1" lower than stock)
