one wire..dunno!!!
jsmith200
hey need help jus swapped engines in my 1990 lexus ls400..I have a connector that I don't know where it goes...it is a two wire connector, one wire is brown the other is pink or red can't tell with a blue or green stripe. It is located on the top of the engine on the driver side coming out of the same location as the third fuel injector connector(second from the rear of the engine) on the engine harness. It is approximately 5" long. Any help will be appreciated. thanks josh
could be for the purge valve for the charcoal canister.
Post a pic someone will let you know straight away.
I have seen this connector.
On all 1uz-fe engines it was never plugged into anything.
I am talking about a connector that comes out of the harness in the same spot as one of the fuel injector plugs on the same side the oil/transmission dipsticks are on an LS400 as you explain.
It was also folded and had a zip tie around it to keep out of the way
