That is crazy high. When driving down the road at slow speed, mu oil pressure is 80 psi. At 1000 rpm it is at 70psi. I have noticed that the oil pressure is directly related to engine RPM (this makes sense since the oil pump is connected to teh engine) but the oil pressure relief valve shoudl be playing a part in there so that the oil pressure does not follow the engine RPM exactly, right? I guess I'm a little worried about running a car with oil pressure nearing 100psi. But if this is normal then I guess I can't worry but it just seems so high to me.
