raymondclark0
- 9
- Newcastle UK
Hi folks, Im currently have a 1994 LS400 1UZ-FE bought for a jet boat project but im having some difficulty starting it. I have an ECU from the same year with all four plugs with it (34pin 22pin 16pin 28pin). Three of the plugs on the engine plug straight in, the fourth one isn't on the engine (All four plugs came with the ECU and the colours match the ones on the engine). There is three shorter plugs that i presume go to the dashboard for starting/control with a thick black wire which controls the started solenoid. I tried to match the wire colours with the ones in the tech articles, but the colours don't match. I did work out that the black/red. black/yellow and black/orange are important 12v feeds. I tried connecting those three wires to the 12v supply. Plus 12v to the yellow/red check engine wire as read in another thread, but the engine only turns over and doesn't start. Will the engine run without the transmission and factory fuel pump on the stock ECU? Im not worried about the ECU throwing up error codes as long as the engine runs.
Thanks in advance,
Raymond.
Thanks in advance,
Raymond.
