Ironically I must build a custom Y pipe for my LS400 to work with the GS400 headers I helped design. That is ok as the stock pipes leave a lot to desired. People are also constantly asking me where to find correctly design Y pipes. I am going to build a few of these in very limited quantities so if you are in need of them send me a PM.
For our applications I have designed them to maintain or enhance low and mid range power while enhancing top end. 2.25" feed pipes and 2.50" center size. Design I suggest is stock configuration using two Y pipes to enhance torque. This allows for a single 2.50" center resonator and then dual resonators and then dual mufflers for high flow and good muffling.
Unlike anything else I have seen I have modified the front Y for maximum response and torque with a velocity/one way modification to the somewhat familiar racing merge collector design. This is only for the front Y with the rear Y maintaining a standard racing merge collector design.
