Lambo
Moderator
I know its not a Toyota but i need help, my Mitzi GTO tt 6g72 was using water so i pulled the heads to discover cracks in both  heads on 4 out of 6 cylinders, and someone has been there before in japan and welded it up , but 8 years later it leaks.
I have found a Diamonte 3.0r at a upullit yard and the head looks and measures the same from the outside it is non turbo, is it possable that the head is the same, cams will be different, but could be swapped over,maybe valve sizes would be different ,could it be only the pistons on the Twin turbo will be different to lower the compression.I think the turbo runs about 8.5 and im picking the non turbo would be about 10.1
Is it possible the head would be the same or would they need to mod the area around the valves for the turbo, any help appriecated, i can't buy a pair of turbo heads and so car is now off the road.
Best Regards
Lambo
Best Regards
Lambo
