Min battery CCA?
4000GT
What have people got away with turning over the 1UZ in terms of CCA? (if possible post ratings at -25 degrees if know)... I am hoping 240CCA at -25 in a dry cell will be enough but I may have to run 2 of them :)
Below is some analysis on the battery I am looking at and the temperature based on it being in my garage at ambient.
  • Cold-Cranking Amps = 240
  • CCA Rating Temperature = -13 degrees F
  • Battery Temperature = 50 degrees F
Computation Results:
Computed New CCA is 443, a 84.5 percent change.
Thanks for the link I have used Optima before, but want even smaller! they are going in the cabin, I found a couple of dry cell ones that will do the trick.
