Mechanical guages
Guts
I have water temp, oil temp and oil pressor mechanical guages. Where is the best spot on these motors to tape them in to?
Same place as the current electrical ones are.
The ECU doesn't use the oil pressure or temp guage sensors.
Just remove them and put in yours.
Fitting your oil temp guage is a little more tricky.
You have a choice of fitting it in an oil line, this will give you the temp of the oil delivered to bearings or you can drill the sump plug or sump and sense the temp of the sump oil. The sump temp should be a little cooler but not enough to stress over.
If you water temp sender doesn't fit in the small sender hole it may fit the hole to the left which is usually used by the airconditioner to sense water temp. That gives you 2 options.
On the oil pressure front I'd use a "T" piece and instal your gauge AND and an idiot light (I have one) and even a buzzer so you know without looking when you've run out of oil pressure climbing at some impossible angle.
Thanks Zuf, I was hoping to keep the standard oil pressor light and the standard water temp still working.
