I have searched alot looking to resolve this problem. I have a 94 Lexus SC400 (CA emissions) 200,000 miles. I have a low idle to the point where the car shakes. It looks like it idles at around 200 rpms in drive and 400 in park.
So far in attempt to fix this problem I have changed air filter, pcv valve, spark plugs, distributor cap and rotors, fuel filter, mass air flow sensor, swapped out throttle bodies, tps sensor, checked for vacuum leaks, cleaned iacv I believe thats it. When I first start the engine (cold): the cold start idle is around 750 rpms then it will gradually decrease down to 400 rpms in park.
Sometimes after driving for thirty minutes and then putting it in park the idle won't even get back up to 400rpms. The car shakes due to the low idle. I also have a misfire. I have just recently tried to fix the misfire by replacing the plugs, caps and rotors. The oem plug wires are only two years old.
I am lost with the low idle. I don't know what is causing it. The only thing I have left to try myself that I know of is to replace the idle air control valve (iacv). And with the misfire the only thing I know of to check would be to check each plug wire to make sure it ohms within specs. Other than the low idle and the misfire, the car seems to drive fine.
So here are my questions:
A. What else could cause an engine to misfire
B. What else could cause this low idle to occur all the time?
C. Could the low idle and the misfire be related?
D. If my spark plug seals are starting to leak would that cause it to misfire?
Sorry for the long post, I was trying to describe it the best I could. Thanks in advance for any help. I have been a member on other lexus forums just not this one until recently.
