So Bob going to have a running 6 speed Twin Turbo SC400 Soon? WOW>.....
Bango, I don't believe Chrisman intends this to be a clutch tutorial.bango said:Any Thing is possible,what does 800 lb clamping pressure = to? are clutch's related to 1 lb /HP..? Duh..Please explain..lol
Was this the inexpensive clutch/flywheel setup you were talking about before?chrisman said:hi chris,, the clutch does not bolt to the flexplate.. the clutch/flywheel bolts go thru the flexplate to the crankshaft..
this allows the flywheel to be smaller/lighter.. as for the w58-- i dont know.. the clutch disc hubs were made for the getrag spline.. if the w58 uses the same clutch discs as the getrag-- then yes.. but i dont know if the inputshafts are similar..
maybee someone with some experience in the w58 would now..
