deankdx
who was the engineer, may i ask?kpwemu said:It was fully engineered by a bloke organised by Hopper's Stoppers. I **** myself, A new alternative is to use the Mitsubishi L300 front end which most hot rodders use which is only 10 cm wider than the Zephyr and may be overcome with different offset wheels. I'm leaning toward this option at this stage. How far are you of getting mobile again? Kevin
i have seen and heard of the L300 front end, sounds good...2 inches wider each side is nothing compared to 4.5 inches each side, wider track...
i have been in research and planning mode, if i put it in your terms i have 1/4 of four cars completed i MUST fisnish my XF stock(ish) sedan, getting mild gas cam and engine rebuild as we speek, next might be the conversion from Lexus ute back to standard(ish) as this will take a weekend (worth of time, i dont have much time to spare and not enough money to BUY more)only
then the XE sedan will come together pretty quick(few months or less)
then the Valiant coupe, that i still may sell?????
i dont really care for my Progress,for if i did i would have done it now, but i am definatley inspired by what i see going on in these forums and also still remember the noise and acceleration of the mighty 1UZ
thanks Dean
