How to Modify Supra Injectors
Lex, I'm pretty sure the yellow injectors are lo-impedance, and would need a resistor bank to work.
The green ones a definitely hi-impedance though (same as stock).
Could you check and verify the yellow ones?
Peewee,
I can check it but I am 100% sure they are high impedance just like the Lime Green. However, the 7MGTE (black tip) is low impendance.
Oops..... I need to double check..... to confirm.....
