How do you know if one of your injectors is not closing?
I'd think a rough idle, rich AFR, fuel pressure dropping off rapidly after you turn the key off, perhaps hard to start, all might be some of the symptoms. Diagnosing it completely would probably involve removing all the injectors and having them flow tested but with back pressure on the pintels to see if any are slow or weak to close, or are leaking.
A good tech with a digital oscilloscope (and really knows how to use it) could be a handy thing to have around.
I've been drooling over these Pico Scopes for the last 3-4 years, and they're just about down to the price I want to pay:
http://www.picotech.com/auto/automotive_oscilloscope.html
Here's an article on diagnosing injector problems with one:
http://www.picotech.com/auto/articles/electronic-fuel-injection.html
Note, it's pretty easy to diagnose a dead injector, but one that's sticking, or leaking, isn't nearly as straightforward. Still I think these scopes are way cool, and nearly every time I'm diagnosing something on the car I wish I had one.
John,
You are too wise.... that was exactly what I had. The above symptoms as I was complainting for the past few months.
Hehehe, I don't know about the wise part David, but these are pretty common symptoms for many fuel system related problems. You just have to isolate the problem now.
IIRC, you said your fuel pressure was dropping off fast after the key was turned off, and you'd already changed the regulator, so IMO it could still be the check valve in the fuel pump, a leaky injector, or a leaky o-ring somewhere in the system before the regulator.
If the fuel pressure wasn't dropping off fast after key shutoff, then nearly all the symptoms mentioned in my first post could be ignition related too.....
We used a mighty vac and the pressure drop very fast. I changed the FPR and little later I also changed the fuel pump with possible leaky valve. However, with two above changes it didnt help at all. All those symptoms were killing me. I was so frustrated. Finally I just change to a set of stock injectors and reprogram the split second and they car started right away.
So it seems it was a sticking or leaky injector all along?
Glad you got it sorted; are you going to have these injectors tested to confirm the problem? Be sure to mention there's a leaky one in the bunch, else they may just flow test them under static conditions, and that won't find the bad one.
