mickesanda
First run
Hi guys,
Today i started the engine for the first time with the supercharger.
Here is a short movie with the first run:
http://www.youtube.com/watch?v=Ow_7fPCn-Dk
The idle is a little rough, but not very bad, it tends to stop but it doesn't. I believe that part of the problem is that the ECU has been reset and needs to relearn (my aggressive driving style), but i need some advice on what the problem may be.
I took it for a spin on the yard of the workshop, it felt powerless. The bypass valve seems to be working correctly, whenever i floor it, it closes the valve and it releases air when i take the foot of the gas pedal. It is partly open at idle. Does it sound like it works correctly? I have no experience with bypass valves. I tried to change it with the bov i had from my old Passat, but it behaved the same, the bypass valve seemed to work better.
Any ideas are greatly appreciated.
/Mike
			Hi guys,
/Mike
