krayn
- Messages
- 511
- Location
- Victoria, Australia
Hi all. Here are some pics of the engine mounts that I made to suit a HK HT HG Holden. The plate that goes onto the engine is cut out of 10mm flat plate and the sides and the plate that bolts to the rubber mount, (which is a standard HT - HQ 308/ 253 v8 engine mount) is made from 6 mm mild steel. It seems to bolt in and sits the engine all square. All up it cost aprox $10 to make, a lot cheaper than $175 from Castlemaine rod shop, But about 10 hours work, and the engine sits exactly where I wanted it to. Now for the sump, This will be tricky, will post pics of the sump as it progresses. Kris...
