Aint seen ne1 post one so I figured I'd write one real quick.
SMAW (Stick)
Carbon Steels:
-15 runs DCEP & is easier out of position
-18 runs DCEP and AC. Has less arc blow & good for thicker metals.
Cast Iron:
I do not recommend welding turbo manifolds. Because the nickle will expand much more than the cast iron under excessive temperatures, it will eventually crack. (The best way I know to weld an exhaust manifold successfully is oxy-fuel / tig with a real cast iron filler.)
Aluminum:
E4043
I do not recommend. Requires too much experience, not enough common selection of rods.
GMAW (mig), and GTAW (tig) wire / filler
Carbon Steels:
ER4043, ER4145, ER5356 are common.
Please consult a chart for the correct choice.
FCAW (flux-core, wire feed. sex welds)
Carbon Steels:
GMAW (mig) gas selections!
Short Circuit (low currents & voltage ranges). Primarily small boxes.
Carbon Steels use C25. High speeds, minimum spatter & distortion. Good apperance. Good control out of position. And virtually eliminates undercut if you're remotely in the ballpark of correct welding angles.
Stainless Steels use a tri-mix. 90% Helium, 7.5% Argon, 2.5% C02. No effect on corrosion resistance, minimal distortion. Good apperance, virtually no undercutting, small heat aaffected zone.
Aluminum use pure argon on sheet metal and, 75-25 mix of argon & helium on 1/8" and greater.
Spray transfer (high currents & voltage ranges)
Carbon Steels use argon + 3-5% oxygen. Improves arc stability, easily controlled weld puddle, nice bead, minimizes undercutting. Higher speed welding than pure argon.
Stainless steels use 99-98% argon, 1-2% oxygen. Use 9822 for thinner steels. Use 99-1 for thick steel.
Aluminum use pure argon for the least spatter. Use 65-35 argon-helium, and 75-25 helium-argon when even higher heat input is required.
Higher weld currents need more flow rates. For short circuit typically 10-15 CFH is good. For spray transfer 15-40CFH is typical, helium mixtures may require 40-50 CFH as it's lighter than air.
GTAW (tig) gas & electrodes!
Don't be a dork. Use 100% argon, or a helium mixture for DCEP & aluminum welding. 15-20CFH with argon. 30-50CFH for helium mixes. If using a large cup (#8+), or a gas-lens the CFH requirement may be half of normal; all things depending. 10-15CFH.
Any corrections, suggestions, additions, go for it!
SMAW (Stick)
Carbon Steels:
- E6010, Run DCEP. Flat beads, deep penetration, common & cheap, good on poor preparation. Good for root passes, especially on pipe.
- E7018, Run DCEP or AC. Low-hydrogen, great for fill / cap passes, low skill involved, high quality welds.
- 301-305 to 301-305 Stainless steels use E308-XX
- 301-305 Stainless to non-stainless steels use E309-XX
- 316 Stainless steel use E316-XX
- 321 & 347 Stainless steels use E347-XX
Cast Iron:
- #55 (EniFeCl), stronger, less ductil & cheaper.
- #99 (ENiCl) high nickel, easier to weld
Aluminum:
E4043
Carbon Steels:
- ER70S-2, Easy to weld all positions, most common, least cost. use C25 gas.
- ER70S-6, Most resilient to mill scale & rust, use C02 & higher currents.
- ER70S-A1, Even more expensive. Addition of Moly increases weld strength & corrosion resistance at high temperature.
- For 301-305 to 301-305 stainless steels use ER308, or ER308H. The higher carbon content of ER308H rods increass strength at high temperature.
- For 301-305 stainless steels to carbon steel forgings use ER307.
- For 301-305 stainless steels to carbon steel castings, and general mild carbon steel use ER307, or ER309. 307 is stronger at high temperature, 309 is more resistant to corrosion.
- For 316 stainless steels use ER316, or ER316H. The higher carbon content of ER316H rods increass strength at high temperature.
- For 321 stainless steels use ER321 or ER347
- For 347 stainless steels use ER347
Carbon Steels:
- ER71T-1M, DCEP. All position (no downhill), cheap, dual-shielded requiring C25 shielding gas, multi-pass is OK when flux is cleaned.
- ER71T-7, DCEN. All position (no downhill), cheap, no shielding gas, multi-pass is OK when flux is cleaned.
- ER71T-9, DCEN. ALl position (no downhill), cheap, dual-shielded requiring CO2 shielding gas. multi-pass is OK when flux is cleaned.
ER71T-13, DCEN. All position (no downhill), cheap, no shielding gas, single pass only. If you have a chinese welder, or are welding under atleast 180amps. This is the flux-core wire you want to buy.
- 2% thoriated (red) for DCEN steels, grinding dust is radioactive, but longest useable life
- 2% ceriated (orange) for DCEN steels and AC welding on inverter units, not radioative.
- 1-1.5-2% lanthanated (black, gold, blue) for DCEN steels. not radioative.
- Pure tungstens (green) for AC welding on transformer units.
- Zirconiated (brown) for AC xray **** you'll never do.
