egr valve and idle 94 LS 400
yardbuzzard
Can a bad egr valve cause idle problems? This car runs about 1100 rpm's at idle.You can tap the egr valve a time or two and it will idle at 650 and run great till you turn it off and restart. then back to high idle.
thanks in advance.
Remove the valve, clean it extensively with carby cleaner, let dry, reinstall.
Test.
Let me know if it works.
