scotturnot
- Messages
- 954
- Location
- central US
Hey guys. Just got my lextreme EGR kit. Bolted all the blanking plates on no problem - perfect fit
But there are two things im not sure of...
1) Where exactly am i supposed to put the resistor?
The connector i pulled off the EGR valve has 6 pins so not sure which to connect the resistor to (if thats where its supposed to go). Instructions state the temp sensor connector where this resistor is supposed to go is right under the EGR Valve but i havent got anything directly underneath. There are two small valves either side which have got two pin connectors on but the left one is shown un-touched in the instruction pictures so maybe the right one with the two hoses going into it?
2) Kit came with a small white 't' piece. Doesnt mention this in the instructions. Any ideas or should i just forget about it?
Here is a picture of my engine. EGR Valve in the middle is gone now. So all i have left is the 6 pin connector that used to be attached to it, the 2 pin connector on the left which i have circled and another almost identical one on the right which you cant see as its under the hose. But whatever it connects to has those two smaller hoses that you can see going into it.
Thanks guys
My US 97 SC400 EGR looks like this as well and the CEL comes on after about 20 mins of driving. Has anyone figured out where the resistor goes?
Thanks,
Scott
