Wanted Cylinder heads
kildea
I just purchased a set of heads to rebuild but turns out I got screwed on ebay ... so I'm looking again.
I need a set of cylinder heads that are in good enough condition to be rebuilt ... so no deep gouges on mating surfaces that would require welding to repair, and no cams rusted to the lifters ... burnt valves can be replaced but ideally I'd like something complete.
So please let me know what you have, I would be happiest if I could find a set of later non-vvti heads, for example a pair from a 1994+ ls400 - since the oem cams have a bit more meat on them in that era.
I'll need the heads shipped to 02482, so I'd need to get an approximate quote for the set shipped.
Try PM'ing our member Aliga; he's always parting out UZ engines.
Failing that, sometimes complete UZ's are so cheap off eBay you could buy the whole engine as cheaply as a complete set of heads with cams might cost.
There's a salvage yard up in CT, IIRC that gives really good service.
