COFFEE
- Messages
- 172
- Location
- Sydney NSW
Does anyone know all the diff's between the two variants of the engine ?
eg: Ecu, plenum etc
Regards
Stephen
eg: Ecu, plenum etc
Regards
Stephen
LS400 - YESZuffen said:Coffee there are actually 3 variants of the engine. Crown, SC400 and LS400 (also called Celsior)
The cosmetic differences are the plastic plug covers and the badge on the plenum. The Crown ones say "Toyota" also the plenum badge on the Crown says "V8 4 Cam".
The Other engines have an "L" badge on the plenum and "4 cam 32 valve" (don't quote me on this as I don't have my car with me) on the plug covers.
LS400 same as CrownZuffen said:Power steering
Crown p/s pump has the resevoir attached to it.
SC400 uses remote resevoir.
LS400 1 line to the coolant reservoir onlyZuffen said:Thermostat housing
Crown has no blead lines off the housing.
SC400 has 2 bleed lines from the housing
BlownV8 said:-toyota badge on plenum - Crown Engine
thefastj said:nup, not a Crown then.
Crown engines have "V8 4 CAM 32" on the plenum.
Crown have "Toyota" printed on one of the spark plug covers.
