Crown ECU Sockets
Quadcob
Does anyone know where I can get sockets similar to the ones on an early Crown ECU(stand alone motor ecu). I want to make a lead up to plug into the motor loom and then plug into a aftermarket stand alone ECU(Adaptronic). I don't won't to strip down a working ECU to get the parts. I was hoping that these plugs might be available.
Warren
Thanks for your suggestions.
I checked out the wreckers and found an identical socket from a 7MGE Soarer. Also I found that a early 90's Mitsubishi Lancer has a similar socket on there ECU that is available from Dyiautotune that would have worked as well
Warren
