righto here is the go, i have set up my clutch to test out whether my custom clutch set up is working
( 1uzfe to w58 supra gearbox manual conversion)
so i bleed the clutch and get some one to press it when its in gear the tail shaft doesn't spin( its not connected to the diff) but the throw out bearing is pushing the pressure plate fingers slightly.
so i got a 1/4 inch extension that is 10mm longer than the rod that pushes my clutch fork, that works perfectly but now the clutch has no play and the release bearing is going to constantly touch the pressure plate (result is it machines the fingers off) so how do i make my slave work? its a w58 gearbox and a w58 clutch slave.
