Central locking playing up -92 SC400
maverick
Hi guys
One day without thinking i unlocked my 92 SC 400 with the key instead of the keyless entry/immobiliser.
We're all aware of the 92 SC 400 automatically locking all doors once you exceed 25kmph.
The result of my abovementioned actions is that now that the drivers side door does not lock once above 25kmph and that the keyless central locking also does not work for the drivers side.
Is there any way i can clear the central locking memory and start again to function only with the alarm/immobiliser?
Thanks anyone.
Hi guys
Thanks anyone.
You may try disconnecting and reconnecting the battery after 10 minutes. Hope it'll solve the problem. I have a '95 SC400 but I never this problem. I use the aftermarket alarm instead.
Yes, disconnecting the battery for a short time will reset the factory alarm settings....You should be ok as Steve has mentioned...
