can you put the 2jzgte in the sc400?
Yes its possible but you better off buying a SC300 instead. However, for the money you put in the swap, you can spend it one SC300 NA-T with build internals and you can install oil jets into your GE block too.
The swap is about 7-9k (complete). With that amount of money you can get many go fast ungrades with a nice single turbo.
I would recommend getting your GE block build with oil injectors, forged pistons, forged H beam rods and studs. With some head work, you are in much better position then just a stock GTE swap.
na-t would be cheap because you son't need aftermarket internals to make big hp and definatley the limit of pump gas with only a thick metal headgasket and arp head studs. Check out clubna-t.com for faq's and other general info
