Can anyone identify this ?
5020Chris
Hi, just wondering if anyone could ID this part of the wiring loom for me ? Is it some kind of fuse /junction ? Thanks in advance, Chris.
Loom is 1994 ls400 UK spec, now in Hilux.:yup:
its either afew wires all linked to earth
or i see some of the wires might be shielded
bit hard to see yr lighting under the dash sux
never use fluro for photos hehehe
can u just trce it back to the loom somehwere
is it a plug does it come apart
just hard to see
Tracing wires.....
Thanks for the reply sideshow, have traced wires this am, one (brown) appears to go to earth and the other two (green and grey) go to the knock sensors. The thing that is throwing me is that these two wires appear to be like a coax cable like on a TV ariel, the internals go to ecu but the external covering goes to that plug which is a joiner. Is this for radio / ignition supression or am I way off ? Thanks in advance, Chris.
yer the coax wire is shielding wire for speed or rpm sensor or might even be
traction control wires
if the main wire inside the shielding goes to the ecu then leave it
the covering would be some sort fo earth which will go to that plug and join with other wires to earth
so im guessing all the wires should go back to earth and that funny plug u have is just a joiner
