Arp stud torque
200sx-v8
Do anyone know what torque to use on the arp head, main and rod studs and bolts?
Could not find the correct info anywhere?
Should be on the instruction sheet that came with the bolts/studs. If there is no instruction sheet, are they ARP ??????
The last set of ARP rod bolts that fitted standard rods were 45 lb/ft
ARP moly assembly lubricant on thread and under bolt head.
Torque to 45 lb/ft, loosen off, torque to 45 lb/ft, loosen off, final torque to 45 lb/ft.
Thanks RMS,
I double check the box.
10 mm x 1.25:
Torque with 30 wt oil 54 lbs (Not recommended)
Torque with ARP moly 42 lbs with 10,600 lbs preload
The rod bolts are the arp that came with the Argo rods. Could not find any torque data with them.
Thanks for the 10x1,25 data!
There are three series of ARP bolts/Studs
ARP 8740
ARP 2000
ARP L-19
They are have different rating. I am not sure what Argo rods come with.
