2 200sx-v8 New Member Jun 18, 2007 #1 Do anyone know what torque to use on the arp head, main and rod studs and bolts? Could not find the correct info anywhere?
R rms Member Jun 18, 2007 #2 Should be on the instruction sheet that came with the bolts/studs. If there is no instruction sheet, are they ARP ??????
R rms Member Jun 18, 2007 #4 The last set of ARP rod bolts that fitted standard rods were 45 lb/ft ARP moly assembly lubricant on thread and under bolt head. Torque to 45 lb/ft, loosen off, torque to 45 lb/ft, loosen off, final torque to 45 lb/ft.
Lextreme II Active Member Jun 18, 2007 #5 Thanks RMS, I double check the box. 10 mm x 1.25: Torque with 30 wt oil 54 lbs (Not recommended) Torque with ARP moly 42 lbs with 10,600 lbs preload
2 200sx-v8 New Member Jun 19, 2007 #6 The rod bolts are the arp that came with the Argo rods. Could not find any torque data with them. Thanks for the 10x1,25 data!
Lextreme II Active Member Jun 19, 2007 #7 There are three series of ARP bolts/Studs ARP 8740 ARP 2000 ARP L-19 They are have different rating. I am not sure what Argo rods come with.
