Paulwolf
- 11
- Rockhampton, Qld
I have a 2uz, which i am building for an offroad racer
it needs to have as much torque as possible, and about 450 - 500 hp
I have decided on using the 2uz bottom end - already have it
I have decided to use an intercooled m112 - already have it
I have pulled the heads on the 2uz, and have bought a set of 1uz heads
I have been trying to do some math to work out the best way of making this work,
I know - i will need different pistons
- the 1uz heads have 43cc chambers,
- head gaskets from my 2uz were 1.15mm thick
- 2uz pistons are 0.65mm above the block
from previous posts, dish in piston is 29cc, but i dont know if this takes into account the dome portion or not. dome rises some 3.2mm above block and has dish in the middle
has anyone measured the 2uz piston crown relative to the block at TDC?
can anyone tell me the combustion chamber volume of 2uz head
trying to work out the stock CR for this motor, (I know it is supposed to be 9.5)
then what I need i need to do to a piston to clear the 1uz head and still maintain 9:1 CR or better
lextreme, I know you have done this?
Paul
Paul
