almost completed.supercharged..pipe question.help
zen
almost done..blew gearbox up again so while waiting for rebuild doing sc install..
so..
A.)vac pipe take off to brake servo...comes from intake to supercharger after throttle body???..yes or no (if no,where from please??)..
B.)vac pipe to supercharger boost bypass valve..from same as above??yes or no (if no where from please??)
C.)engine breather pipes..one way valve from one bank going to inlet manifold after s.c....valve blocks boost from entering bank..other bank vents to inlet to sc,no one way valve..vents before or after tb??is this correct???what one way valve to use??
thank you..
a..dooh...goes to boost side of sc..via one way valve so it dont see boost...(max vac position...
b?????
but then again..vac will be the same pre sc as post on idle over run as bypass valve will be open....
